C1 - 1958 230hp automatic.....Does anyone know where the Distributor LEad wire and the Washer Motor mount Ground wire connect ? I know one of them connects to the value cover screw BUT I don't know which one and THEN where does the other go ? Please Help Eric
C1 Distributor Lead Wire
Re: C1 Distributor Lead Wire
Eric,
The Black Dist Lead wire connects to the "-" terminal on the coil.
The Black Wiper Ground connects to the Passenger side inner rear valve cover screw.
edit.....If you have a Wonderbar Radio, it's Black ground wire also attaches to that same valve cover screw.
P8010028.jpg- Top
Correct Jerry, the grounding scheme is totally different for '56 & '57.
There is a Cowl Vent Brace Stud that comes through the firewall. The Wiper Motor ground attaches to it. Section 12 Sheet 6(View C) in the AIM shows the stud location. Section 12 Sheet 12 shows the main Black Ground in the harness attaching to the cowl brace.
FOA 102 Radio option Sheet 2 shows the radio mounted and connecting ground of it's case to the Cowl Brace under the dash. This may be how it gets it's ground. I'm not sure if the radio has a separate ground wire attaching to the cowl brace main ground or not. I have a '56 in the shop radio equipped and can take a look later. One of the others more 56/57 knowledgeable may jump in before I get out there.
Rich- Top
Jerry, Here's a thread I just searched about grounds that I was in on.
https://www.forums.ncrs.org/showthre...434#post659434
The main ground for the harness actually connects to the Left(Driver Side) inner valve cover screw. No other grounds go to the VC's.
Rich- Top
