Car is a 1961 corvette F.I. model. Original short block was replaced under warranty with a 3959532 cast block assy. which is stamped as CE4N34145 . Bottom right side of the block is hand stamped with the following numbers; S 374164. What does this number mean? Second question: bottom flange inline with each cylinder is stamped with a letter, i.e. J or K. What does this mean?
Any information would be appreciated, thank you
