Original Battery Cable Spring Rings - NCRS Discussion Boards
  • Floyd B.
    • November 1, 2002
    • 1046
    I searched the forums but I have not been able to find a good detailed description or pictures of the spring rings on original '69 battery cables. The TIM&JG says very little. I have seen some that are claimed to be NOS that have an concave surface on the side that faces away from the battery and raised lettering that reads "SPINGRING." On the underside (side that faces the battery) of the spring ring is raised lettering that reads "BATTERY." Can someone please confirm the correct configuration of the spring rings or better yet, post a picture of an original.
    My car is 427/390, w/o A/C, manual trans if that matters.
    Thanx
    "Drive it like you stole it"
  • Jeff P.
    • 797
    Re: Original Battery Cable Spring Rings
    Here you go Floyd. Thisimage.jpg is a set of cables off a 68. First two pics are the negative second two are the positive.
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
    • Floyd B.
      • November 1, 2002
      • 1046
      Thanx Jeff, just double checking - these are known to be originals? If so, do they have the last four digits of the part number stamped on them with white ink?
      • Jeff P.
        • 797
        Your welcome Floyd. They came off a 68. I'm planning on using them on the 68 resto. Here is the stamp on the negative cable. Nothing on the positive cable.
        • David L.
          • July 31, 1980
          • 3310
          My 1969 Chevrolet Parts Catalog (Oct. 1968) lists the following:
          battery ground cable (Gr. 2.341)
          68-69 CORVETTE 6295176 (13" c/c holes)
          68-69 CORVETTE 6295070 (18" c/c holes)
          battery to switch cable (Gr. 2.342)
          68-69 CORVETTE 6295212 (85" c/c holes)
          My 1969 Corvette Parts Catalog (Oct. 1969) lists the following:
          Gr. 2.341
          68-69 Corvette (1st design) 6295070 (18" c/c holes)
          69 Corvette (2nd design) 6297645 (16 1/2" c/c holes)
          Gr. 2.342
          68-69 Corvette (1st design) 6295212 (85" c/c holes)
          69 Corvette (2nd design) 6297644 (78" c/c holes, side terminal)
          The 1969 Corvette AIM lists GM # 6297644 (+ cable) and GM # 6297645 (- cable) on UPC 12, sheet A12 (drawing revised 11-6-68).
          Dave
          • Floyd B.
            • November 1, 2002
            • 1046
            Thank you gentlemen. My car is an Oct 4, 68 build so it used the spring ring cables. I now have all the information I need.
