Joe,
I have a similar concern that Lawrence recently posted (re: 69 rear Shock Mount Bad) which you replied:
" You can be sure that GM included the "knurled" area for a good reason. Is it absolutely critical to the function of the part? Probably not but I'd be reluctant to re-use a piece that was worn to the point that the "knurling" was completely ineffectual".
In my case the RH shock mount has a worn looking knurl not unlike the OP and would not bite, although the LH was fine.
The problem is magnified a bit because it's a F41 shock mount to my knowledge is not reproduced.
My question is this: what is the effect on function and can I assume there may be safety risks as well?
I recall reluctantly installing it knowing the knurl was compromised but unaware of any ramifications until I came across the post by Lawrence which got my attention.
There's a NOS RH 3829266 available (not cheap) which I'm ready to secure.
Thank you !!!
Ralph
Thank you !!!
Ralph
