I just installed rebuilt front calipers, brake hoses (with new copper washers), and Delco 17D8 pads on my '77. The calipers are rebuilt units from Precision Engineering and use o-ringed pistons. I noticed that the pistons were very difficult to press back into the caliper when the pads were installed. Got everything installed, flushed the brake fluid using the gravity method (works pretty well), and buttoned her up and went for a drive in my neighborhood.
Here's the problem: When I raised the front-end after my initial drive, the front wheels were very difficult to rotate. This was not the case prior to replacing the calipers. I understand that there should be a little drag from the brake pads, but this seems way to be an excessive amount of drag.
Is this typical of o-ring piston calipers? Should the wheel be able to rotate fairly easily but then stop fairly quicky due to a proper amount of brake drag? I have to put effort into turning the front wheels, and the wheel stops as soon as I stop rotating the wheel.
My concern is that driving on the highway would probably overheat the front rotors. The rotors may be original (still rivited and look like they are 37 years old), so I'd hate to damage them.
Part of me says to work with the vendor and get new calipers and send back the rebuilt units. Thanks in advance.
