63 Fuel injection accelerator springs - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    Early '63 FI's used a silver/gray accelerator return spring. Actually the spring was originally use on '57 and '58FI's.
    My question is this.
    What time frame was the silver gray spring switched to a blue spring. Thanks very much, John
  • Mike E.
    • February 28, 1975
    • 5134
    Re: 63 Fuel injection accelerator springs
    I've never seen a real 62 with one.
    • John D.
      • December 1, 1979
      • 5507
      What do you mean Rev Mike? You mean an early 63?
      • Mike E.
        • February 28, 1975
        • 5134
        No, a very late 61!
        • Michael H.
          • January 29, 2008
          • 7477
          JD
          The silver spring for early 63 FI cars was replaced in production with a blue spring on 25 Oct 62. This comes from the original NPC (notice of production change) that shows the exact date that the change occurred on the line.
          Unlike dates in an assembly manual that are almost never the same as the date of the actual change on the line and can be off by weeks or even months. (the rear control arm pivot bolt on 63 comes to mind)
          The springs were actually painted silver.
          You are correct on the application too. The 7014730 (?) silver spring was the very same as used for 57 with FI.
          • John D.
            • December 1, 1979
            • 5507
            Originally posted by Michael Hanson (4067)
            JD
            Mike, Now that's an answer that I have been wondering about for an eon. Wish I had asked before. Thankyou very much.
            Yes the '57 spring was painted silver. I have the Dupont formula for the silver paint for that spring. Much appreciated. John
