Question Does anyone have a picture of the original Battery cables Ground and positive.I searched and could not find any.I believe mine are the original Spring ring ones. and are pretty beat up.I bought a set from paragon and returned them did not seem even close and felt kind of cheap for repros.Thanks
1961 Battery Cables
Re: 1961 Battery Cables
I didn't think '61 used spring ring cables. Maybe a change for late cars? 62 uses them for sure.- Top
My 1963 Chevrolet Parts Catalog (Oct. 1962) lists GM # 2979805 in Gr. 2.342 as the "+" cable and GM # 3716571 as the (-) cable for 55-61 Corvettes.
My 1957 Chevrolet Parts Catalog (Mar. 1957) lists GM # 3716571 as the (-) cable for 55-57 Corvettes.
I sold my 1961 Corvette Parts Catalog years ago.
There is a NOS 2979805 cable currently on Ebay (not mine) for big $. The 2979805 cable may or may not be correct for a 1961 as parts in the parts catalogs are service parts and not necessarily the exact same as assembly line parts.
Dave
- Top
I'd say that 2979805 is a service replacement for many.
The 1961 AIM shows terminal clamps with bolts
+ 3750025
- 3716571
The 1962 AIM shows Spring Ring terminals
+ 2979911
- 2981079- Top
Sorry I confused everone here meant to say were they spring rings . mine are NOT. Here is a picture just pulled them out.- Top
pictures of it now- Top
Apparently the 3750025 cable was also sold over the counter but was discontinued in June 1962 and replaced with GM # 2979805 according to Chevrolet Parts History.
Dave- Top
Bill, How are you doing? I have not seen you for a while. I looked at your pic.s it appears like the braded cable surely appears to be original. The other appears to be a Delco replacement. As you found out, Some of the repro stuff is not quite as expected I have found this out all to often with my 63 and 72 cars. Are you planning on getting your car judged this year?New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Thakns . That's what I am working towards. Just did rear main seasl and pan gasket. Trying to get here all clenad up. pulling tranny next and doing the second gear syncroBill, How are you doing? I have not seen you for a while. I looked at your pic.s it appears like the braded cable surely appears to be original. The other appears to be a Delco replacement. As you found out, Some of the repro stuff is not quite as expected I have found this out all to often with my 63 and 72 cars. Are you planning on getting your car judged this year?
- Top
Are you tackling the transmission yourself? If you need a hand let me know. I also have a supplier to work with for parts.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
- Top
So is that to say the ones on the vendor sites are not actually correct (e.g. Paragon & Corvette Central)?
William, could you post another picture of the clamp end of the negative cable? Also what length is it?
Anyone have an original positive cable of which they can post pictures?- Top
