1964 coupe factory AC. Serial number for the tag on the AC evap housing/box? - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    Since i do not have the original tag that was placed on the outer AC evaporator box on my factory AC 1964 coupe how do i find the serial number for the AC evaporator tag?
    I suppose it will be impossible to have the correct number but i would like to have the number as close to correct as possible
    I have a serial number that is placed on the evaporator housing for a 1963 but that serial number will not be correct
    The production date for my car is December 6, 1963
    1964 Corvette Harrison Air Conditioner evaporator box metal emblem i need the "almost" correct serial number for
  • Dino L.
    • February 1, 1996
    • 694
    Re: 1964 coupe factory AC. Serial number for the tag on the AC evap housing/box?
    Best pictures I have...probably don't do you much good, this is a October 63 built 641 079.jpg1 081.jpg1 089.jpg
    Dino Lanno
    • Claus S.
      • December 30, 2010
      • 414
      Thanks Dino
      The picture is a bit small so it is not easy to see what the numbers are on the tag
      Can you tell me what the numbers on the tag on the AC evaporator housing is on the outer AC evaporator housing you have?
      What are the numers on the left side and on the right hand side
      • Harry S.
        • July 31, 2002
        • 5258
        These are mostly from July 63's.
        • Harry S.
          • July 31, 2002
          • 5258
          The last picture....
          • Claus S.
            • December 30, 2010
            • 414
            Thanks Harry Those picture helps me a lot
            I was sure that you could order the tags with the numbers and letters you wanted ready stamped but that was wrong
            Just heard back from the company that sells the metal tags for the AC evap box and you have to stamp the tag yourself
            • Claus S.
              • December 30, 2010
              • 414
              1963 AC evap tag. Bilde 3.jpg Harry, NCRS member July 1964 AC evap box tag. Bilde 1.JPG
              The picture above to the left is what i think is what it says on the 1963 AC evap box i have compared to Harrys July 1963 tag above to the right
              Any know who stamps AC evap tags or do you have to do it yourself?
              • Harry S.
                • July 31, 2002
                • 5258
                Originally posted by Claus Roger Schjerverud (52628)
                [ATTACH=CONFIG]52050[/ATTACH] [ATTACH=CONFIG]52051[/ATTACH]
                Claus, is the 67D a 1967 date? I think I would stamp it with a 64.......
                • Harry S.
                  • July 31, 2002
                  • 5258
                  Claus, look at the numbers on this one......
                  • Claus S.
                    • December 30, 2010
                    • 414
                    Thanks Harry for the link
                    The tag on the one from ebay have the following letters: EBA 70 64B in the left field and the serial number is 0001392
                    The tag for my car should be something like: EBA 70 63D and the latest letter for 1963 made C-60 cars and a serial number earlier than 0001392 since my car
                    was built December 6, 1963
                    Any knows if there is a parts store that stamps the tags or do i have to stamp the serial myself?
                    I asked one store that sells this tags yesterday and they said i have to stamp the metal tag myself
                    • Harry S.
                      • July 31, 2002
                      • 5258
                      I don't follow your logic. I think the 0001392 is the serial number of the unit not the VIN of the car. If a July built 63 has 63G then I would think a 64 model would be something after 63G not prior.
                      • Claus S.
                        • December 30, 2010
                        • 414
                        Harry i was thinking of the date on the tag from ebay which have a 64 B tag
                        So i will need a tag that have a serial number after your 63 G evaporator tag but before the 64 B evaporator tag from ebay
                        Left Harry`s 63 G tag and to the right 64 B tag from ebay
                        I suppose that the G in 63 G on Harry`s tag and the B on the 64 B on the ebay tag indicates the month of manufacture for the year?
