Need Confirmation on 1968 Corvette Seat Belt Layout - NCRS Discussion Boards
  • Russ T.
    • May 31, 1989
    • 113
    I am finishing up an interior on a '68 that had the interior gutted and the parts in boxes
    when purchased.
    The 1968 Assembly Manual gives virtually no information concerning the layout of the
    seat belt assemblies (no shoulder belts). I researched the archives and think that
    I understand the correct installation, but I need someone to corroborate
    that I understand it correctly:
    1) The retractors (8.5-in. black plastic casing) mount beneath the seat under the carpet,
    and bolt on the fiberglass floor.
    2) The belt then runs around the indented outer channel of a chrome corner bracket
    under the carpet that's secured by 3 bolts to the fiberglass floor next to the
    rear of the sill plate, making a 90-degree turn upward through the carpet.
    3) The seat belt then passes through a slit that's cut in the carpet that's
    at least 3-in. wide. In this slit was originally mounted a clear vinyl insert
    that was tucked in the carpet like the grommet for the dimmer light switch.
    I understand that these inserts are rare and unattainable today.
    If this is correct, I don't see what would keep the retractor from perhaps
    pulling the lap belt completely back through the slit in the carpet when it's released,
    since there's no stop there. Is this correct or am I missing something?
    BTW, a big "shout-out" to Snake-Oyl for their beautiful seat belt work.
    They've done 3 pairs for me and they are the best, bar none.
    Russ Trotter
    NCRS #15044
  • John C.
    • January 1, 2005
    • 616
    Re: Need Confirmation on 1968 Corvette Seat Belt Layout
    Russ
    With a 68 it is sometimes hard to say what is correct as they went through so many changes in the course of the model year.
    Your statements on basic layout are correct.
    Most 68's did not have retractors. Both belts were a fixed length. The judging guide mentions that early car may have retractors but I haven't seen one yet to know how that worked.
    Some cars had plastic grommets around the slit in the carpet and others did not. It seems very random. Carpet color probably has something to do with it. If equipped with the gromment it was the color of the carpet. My 68 has the gromment and the slit is 6.5 inches long. Unless you saved the gromment from your old carpet you are out of luck as I know of no one who reproduces them. No one can tell you just the slit is wrong but it just doesn't look finished this way to most people.
    John
    • Russ T.
      • May 31, 1989
      • 113
      John,
      Thanks for your input. This car is an early production vehicle (#1501, Oct. 5, 1967)
      and all of the interior pieces appear original, including the seat belt retractors.
      I did find the floowing on E-bay, labelled as "Seat Belt Carpet Inset Grommets":
      http://www.ebay.com/itm/1969-1971-C3-CORVETTE-SEAT-BELT-CARPET-INSERT-GROMMETS-/170722766845?pt=Motors_Car_Truck_Parts_Accessories &vxp=mtr&hash=item27bfdeaffd
      They are specified as being for '69 thru '71 only, but I'm not yet sure why they wouldn't work on a 1968.
      • John C.
        • January 1, 2005
        • 616
        Russ
        That looks Like the grommets I have on my car. I don't see why they wouldn't work for a 68.
        John
        • Robert N.
          • November 9, 2011
          • 67
          How does the rubber grommet attach to the carpet, staples? How many and from which side?
          Thanks, Robert
          • John C.
            • January 1, 2005
            • 616
            Robert
            The grommet is glued in.
            John
