freeze plugs - NCRS Discussion Boards
freeze plugs
  • Michael F.
    • 745
    freeze plugs
    what size are the freeze plugs on the side of a 66-67 big block??
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
    Re: freeze plugs
    Michael------
    1-3/4". GM #3743389 and still available from GM. However, these are steel plugs. I prefer brass.
    • Michael F.
      • 745
      Re: freeze plugs
      thanks, do you use any sealant or install dry, thanks and I like brass also.
      Michael
        Re: freeze plugs
        Michael------
        Always use sealant. Permatex #2 works well or you can even use RTV.
        • Mike M.
          • May 31, 1974
          • 8365
          Re: freeze plugs
          glass bead the exposed surface of the brass soft plugs so paint will stick to them.mike
