Need help with '66 knock off wheel cone - NCRS Discussion Boards
  • Robert B.
    • May 31, 2005
    • 163
    One of the cones on my '66 coupe has a slightly smaller diameter than the other three. It would be logical to assume that that one cone has been replaced, but which is correct? The wheels are original KH wheels, correctly dated for the car.
    And where would one find the "correct" cone?
    Bob
  • Russ S.
    • April 30, 1982
    • 2161
    Re: Need help with '66 knock off wheel cone
    I believe your first picture is the correct one. Judging guide says the distance from the fin to the edge of the cone should be 1/8 inch. The other is most likely a repo.
    • Wayne M.
      • March 1, 1980
      • 6414
      Here's 2 pics of original '66s (cones never been off) beside same 2 views of a set of Western-KHs.
      There's also another parameter; the gap between the top of the cone and the spinner, the result of the different radius of the lip (or something else in that area.
      • Russ S.
        • April 30, 1982
        • 2161
        Wayne, It looks like according to your originals that the judging guide isn't correct in it's statement that there should be an 1/8 inch gap between the cone and the fins as yours look to be closer to 1/4 inch.
        Originally posted by Wayne Midkiff (3437)
        Here's 2 pics of original '66s (cones never been off) beside same 2 views of a set of Western-KHs.There's also another parameter; the gap between the top of the cone and the spinner, the result of the different radius of the lip (or something else in that area.
        • Robert B.
          • May 31, 2005
          • 163
          Thanks, guys - it's hard to tell any other differences with the wheels mounted. I'm going to pull them off next week to redo brake calipers and I'll do some additional measurements then.
          • Wayne M.
            • March 1, 1980
            • 6414
            Russ --- I guess it depends on how you define the points of measurement. I selected a screwdriver blade that just touched the edge of the cone and the edge of the fin where the machined flat ends. I get 0.21" (caliper). Then, continuing down the un-machined "ramp" of the fin to its root, where it "melds" into the center hub, I get 0.135". So, roughly, yes, 1/4" and 1/8", depending on how you define the points of measure.
            This is on an original '66 stamped B_1_3_66. Here's another pic that might help.
            • Robert B.
              • May 31, 2005
              • 163
              Now that I have the wheels off the car, I have measured the larger diameter of the two cones - the larger is 7 1/8", and the smaller is 6 15/16". When on the wheel, the gap between the cone and the end of the fin measures .130" which is consistent with the judging manual. So I have three cones that are the correct size, and one that is 3/16" smaller. You would think that you would not notice the difference, but it is very obvious.
              Now where would I find a cone that will match the other three?
              Would appreciate any advice -
              Bob
