55 vette carpet screws - NCRS Discussion Boards
  • Don S.
    • February 1, 2000
    • 476
    I lost judging points for not having the proper carpet screws. I saw what was supposed to be a an original vette that had them (The washers were painted red). My vette which is also original has no evidence of holes in the floor which would indicate to me that the screws were not always installed. Does anyone know for sure about these carpet screws
  • John S.
    • July 29, 2009
    • 640
    Re: 55 vette carpet screws
    I seen carpet screws along the side of tunnel on original cars. I do not know if all 55s used them or if the screws were installed as needed.
    • Jerry P.
      • September 30, 1989
      • 85
      Don... would recommend you order the NEW 53-55 judging manual....should answer all your ?'s jerry
      • Don S.
        • February 1, 2000
        • 476
        Thanks Jerry . I have seen one but did not get it. will do-- thanks
        • Chris S.
          • January 1, 2000
          • 1064
          the screws are either philips or clutch head with a finishing washer
          neither are painted.
          Both the old JM and the new one call out specific locations.
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
          • Jerry B.
            • August 31, 1994
            • 416
            Hello, would this apply to 57's? location and type
            • Chris S.
              • January 1, 2000
              • 1064
              Jerry - I am not sure - I would have to look in the 57 JM...
              • Troy P.
                • February 1, 1989
                • 1279
                I've documented quite a few unrestored, low mileage 53-55s. All had screws on both sides of where the floor meets the tranny hump. Unpained Phillips with trim washers. Two on each side.
                Note that the updated manual says, "Measurements (speaking of the distance between the screws) and locations are approximate." The reason it says this is because the installer eyeballed them in where needed. I measured a bunch of them and there is no consistent distance between them.
