3989969 exhaust manifold "date"
Re: 3989969 exhaust manifold "date"
J107 would be October 10 & year ending in 7. Maybe the Chinese patternmaker at the foundry forgot to change the date for a along time or the pattern for the repo. castings didn't have a interchangeable date tag.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Scott------
Very simple. This is a later SERVICE manifold. So, the date code represents October 10, 1977 or 1987 and most likely 1987. How do I know it's a SERVICE manifold? Note the "wagon wheel" symbol followed by a "D". This represents GM Central Foundry---Danville, IL. Original manifolds were usually cast at Tonawanda. However, the Tonawanda foundry shut down in 1984. After that time, big block blocks, heads and certain other parts were cast at Defiance, OH (which did not usually use a casting symbol). Other big block parts, including exhaust manifolds, were cast at Danville, IL. Danville-cast parts usually always carried the "D" casting symbol>
By the way, original exhaust manifolds cast at Tonawanda were gray cast iron. The manifolds cast at Danville were malleable iron, a much better material.In Appreciation of John Hinckley- Top
Joe,You are a veritable treasure trove of knowledge. I always enjoy reading your posts and responses. Just as an aside, I thought an "A" was for August, "B" for September, etc making a "J" for May. Did it change along the way? I know you'll have the correct response. ThanxScott------Very simple. This is a later SERVICE manifold. So, the date code represents October 10, 1977 or 1987 and most likely 1987. How do I know it's a SERVICE manifold? Note the "wagon wheel" symbol followed by a "D". This represents GM Central Foundry---Danville, IL. Original manifolds were usually cast at Tonawanda. However, the Tonawanda foundry shut down in 1984. After that time, big block blocks, heads and certain other parts were cast at Defiance, OH (which did not usually use a casting symbol). Other big block parts, including exhaust manifolds, were cast at Danville, IL. Danville-cast parts usually always carried the "D" casting symbol>By the way, original exhaust manifolds cast at Tonawanda were gray cast iron. The manifolds cast at Danville were malleable iron, a much better material.Leif
Top Flight 2017 Lone Star Regional- Top
Leif -
I'm not Joe, but the dating format using "A" for August (or whatever the first month of model year production was for a given year) was only used on '63-'82 body trim tags for the body build date code. The date code format for GM castings used "A" for January, thru "L" for December, regardless of the model year.- Top
Thanks, John. This is one of the many reasons I follow this forum...learn something new every day.Leif -I'm not Joe, but the dating format using "A" for August (or whatever the first month of model year production was for a given year) was only used on '63-'82 body trim tags for the body build date code. The date code format for GM castings used "A" for January, thru "L" for December, regardless of the model year.Leif
