1969 front suspension rebuild - NCRS Discussion Boards
  • Joe T.
    • October 25, 2006
    • 304
    Re: 1969 front suspension rebuild
    Thanks to all: The diagrams all provided important information. Here are the first 4 pics. I took as many as I thought would show all the angles. DSC01285.JPG Next post has 4 more
    • Joe T.
      • October 25, 2006
      • 304
      Next 4: the third shows where I think the interference might be: foreground, below bolt at the bottom of the rib there is a bright spot. Does the clearance in the pics between the rotor and backing plate look correct? Last to follow in next post
      • Joe T.
        • October 25, 2006
        • 304
        #18
        last couple. Again, does the clearance between the rotor and backing plate seem correct?
        I REALLY appreciate all of the interest and support from everyone here. Many thanks and deepest regards...joe
          • 3415
          #19
          Hi Joe,
          Am I NOT seeing the steering arm in your assembly?
          Or am I missing it?
          It should go on at this stage. I'm not sure it affects your clearance question, but?
          • Joe T.
            • October 25, 2006
            • 304
            #20
            Hi Alan. The steering arm in in the first set of pics. I guess I need one or two from the back for clarity. I have the caliper support bracket bolted to steering armand to the spindle. I tried placing the caliper bracket between the steering arm and spindle, but thatwas just wrong. I will post a coup, e of better pics soonest..thnaks again...joe
            Trying totype on this gablet is the PITS
              • 3415
              #21
              • Joe T.
                • October 25, 2006
                • 304
                #22
                Thank-you Alan! These pics helped a GREAT deal. I noticed two things:
                1) the spindle "boss" at the base of the spindle seems to be a little higher than the backing plate/dust shield on yours, but flush or a little recessed on mine. I don't know why.
                2) Your dust shield lies flat to the spindle, while mine (see attached photos) seems to be raised at some points, even bent or deformed? I don't know how I would have done that in the dis-assembly since it seems pretty robust and not all that fragile. This could be the source of my issue. I may either try to re-form it or just buy a replacement.
                Does this make any sense to anyone?
                  • 3415
                  #23
                  Hi Joe,
                  Looking at your latest pictures it certainly appears that the dust shield has been bent somehow.
                  Also the direction it's been bent would likely cause a problem with the shield's clearance with the rotor.
                  Here's a different pic that shows of how flat the shield is where it meets the spindle, and the shape/angle of the shield's 'legs' as they transition away from that seat area.
                  You might try to straighten your existing shield holding the option of purchasing of a new one in reserve.
                  • Mike E.
                    • June 24, 2012
                    • 920
                    #24
                    Hi Joe,
                    Alan,
                    Perhaps there is a difference between midyears and 1969's but it looks to me you have the bolts that hold the steering knuckler are in backward. All the drawings I have seen have the nuts on the inside.
                    Mike
                    • Joe T.
                      • October 25, 2006
                      • 304
                      #25
                      Hi Mike: I thought that might be the case when I saw Alan's pictures, but I am sure the way I have them is the way they came apart. This also looks correct from the exploded diagrams I've seen with the bolt heads being outboard and the nuts being inboard. Also, when I have been working on this, in my setup, the bolts protruding into the rotor area would seem to interfere with the rotor. Thanks...Joe
                      Example: http://keenparts.com/pages/catalog2....t=440&year=ALL
                      • Joe T.
                        • October 25, 2006
                        • 304
                        #26
                        Hi Joe,
                        Thanks Alan: I cannot imagine how I bent that splash shield but that looks more and more like my problem. I would have NEVER figured that out without your pictures! I don't hold much hope of re-forming it back, since the metal might be stretched out by now, but that's my first option. My only guess about how I distorted it in the first place would be when I re-assembled it for the FIRST time, I must have had some misalignment and when I torqued the nuts, it bent the splash..Many Thanks and deepest regards...Joe
                        • Mike E.
                          • June 24, 2012
                          • 920
                          #27
                          Alan probably knows that. He was just using the pictures to show how the shield looks when installed.
                          Mike
                            • 3415
                            #28
                            • Joe T.
                              • October 25, 2006
                              • 304
                              #29
                              My minor sheet-metal work has cured this problem! Many thanks to all for the assistance. diagrams pics and support! Many thanks again and regards...joe
