Re: Vapor Lock Fuel Choices
That's one. Here are two more started by me.
https://www.forums.ncrs.org/showthre...nd-percolation
https://www.forums.ncrs.org/showthre...r-temperatures
The first thing to insulate is the fuel feed pipe in the engine comparment that goes to the fuel pump inlet.
BTW, the avgas minimum 40 percent boiling point is 75C, and the maximum 50 percent point is 105C. If you want to investigate further you can down load the ASTM D910 avgas spec from the Web.
