59 FI Air Cleaner Assy wing nut - NCRS Discussion Boards
  • Al R.
    • June 30, 1988
    • 687
    Lost the wing nut for my 59 FI A/C housing and can't remember the size of it. Large like on carb A/C lid or smaller ? I still have the threaded rod.
  • Don H.
    • December 1, 1981
    • 1482
    Re: 59 FI Air Cleaner Assy wing nut
    Al, Per the JRG: Mid 1958 through 1960 uses a steel wing nut with no indentations in the wing and is welded to the threaded stud creating a "wing bolt". Don H.
    • Joe M.
      • April 30, 1990
      • 1338
      Should look like this.
      • Al R.
        • June 30, 1988
        • 687
        Thanks Joe and Donald, Mine must have been replaced thru the years as it had a wing nut on an 8" threaded rod. Joe, can you show a close-up of the weld between the nut and rod? Also, what is the length of the exposed rod below the nut? Al
        • John D.
          • December 1, 1979
          • 5507
          Al, Last week I saw an original stud on Ebay. Pics showed the top of the stud so that you can see the correct welding procedure. John
          • Joe M.
            • April 30, 1990
            • 1338
            I don't have that information. Perhaps someone else can provide it.
            • Richard T.
              • February 1, 1979
              • 858
              The stud that was for sale on e bay looked like a good original and did not sell. It was being sold by Justin Beck who is a member
              • Al R.
                • June 30, 1988
                • 687
                Thanks All, I looked on e-bay, but could not find it. I'll contact Justin.
