70 Exhaust tip clamps?
Re: 70 Exhaust tip clamps?
Mike,
A couple of comments.
First, the photos in the AIM are only meant to vaguely resemble the part installed. There are many cases when they are not really correct at all.
Second, VIN 28 has replacement tips and one replacement muffler. I'd bet that the clamps you're looking at may not be original to the car.
The owner might stop in here in tell us, but that's my take on it.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Mike, I believe that Paragon Corvette sells a correct clamps for the tips. in your second pic. that appears like the correct lower half.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Reproduction clamp appears to be zinc plated. Originals were, per JG, natural finish or black, likely black phosphate in some photos I have of low mile cars.
So, if you buy a repro you may want to think about changing the finish.
Also, note the above AIM picture shows nuts and washers - the repro sells a nut with a flange, or integrated washer as an option - see pic below.
2587K.jpgVice-Chairman (West), Michigan Chapter NCRS
As Patrick stated can be ether natural, Black plated I think is black oxide and have seen natural and black plating all in one clamp. What I mean is the threaded section could be natural the nuts washers and body black plated etc. Here is a photo of muffler to tip clamp.Attached Files- Top
Mike
Here is a picture of an original clamp next to a Paragon reproduction clamp
BobAttached Files- Top
Bob, would a little action with a grinder or Dremel make the repro appear closer to the original? Any chance of a photo like Mike's above with them laying on their sides?Vice-Chairman (West), Michigan Chapter NCRS
