56 7266634 Resistor - NCRS Discussion Boards
56 7266634 Resistor
  • Mark P.
    • July 31, 2003
    • 407
    56 7266634 Resistor
    What terminal on the headlight switch should the 7266634 resistor be attached to? Also, I believe the ground end of the resistor should be attached to the dash at the hood release fastener, correct?
    Thanks for the help!
  • Gary C.
    Administrator
    • October 1, 1982
    • 17549
    Re: 56 7266634 Resistor
    Connection's in the AIM Section F.O.A. 102 Sheet 2
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      And I just happened to have a few pics of one to go along with the AIM diagram......Rich
      p.s. I think you mean the radio suppression capacitor, not resistor, correct? 2nd photo big brown cylinder connected to the terminal next to the Red wire going to the Regulator. The other end(Gnd) goes to the brace along with the main harness ground also shown on the diagram 102-2.
      • Mark P.
        • July 31, 2003
        • 407
        Richard,
        Thanks so very much for the pictures. This is perfect. I had a question originally because my other 56 had it installed incorrectly and I didn't want to duplicate an incorrect configuration. And, yes, you are correct, it is the capacitor, not a resistor. Thanks again for the info.
