C1 Horn Wire - NCRS Discussion Boards
C1 Horn Wire
  • Eric A.
    • December 21, 2012
    • 126
    C1 Horn Wire
    Need some help understanding where the horn wire plugs in on the steering column. I understand where it plugs in on bottom of the steering column into the main wiring harness BUT where does it connect to the horn button. The wire I have from corvette central has a bear wire on the end and I cannot find anywhere where the wire is connected or sotered inside the steering wheel. Eric
  • Chris S.
    • January 1, 2000
    • 1064
    Re: C1 Horn Wire
    it doesnt....
    at least on early C1's - the horn is activated when the metal plate under the horn button or trim is depressed - when it is depressed it make contact with the metal trim on the upper bearing - which completes the circuit and the horn honks....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Bill M.
      • April 1, 1977
      • 1386
      Re: C1 Horn Wire
      The wire solders to the upper bearing:
      • Eric A.
        • December 21, 2012
        • 126
        Re: C1 Horn Wire
        Thanks this is what I needed.. BIG help!
        • William F.
          • June 9, 2009
          • 1354
          Re: C1 Horn Wire
          Make sure housing where bearing contacts it when installed still has some original paint on it or apply some "liquid 'lectric tape" for insulation or you'll have a contant ground and contant horn honking.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11302
            Re: C1 Horn Wire
            Eric,
            To solder the wire there, there's a hole under the column to get a soldering gun in there.
            Rich
