My 73 has not been fired up in 7 - 8 months, installed a new battery, turns over fine. Checked the spark from coil wire to ground, spark is orange, checked voltage the on positive side of coil with the key on pos., only getting around 7 1/2 volts. Any ideas?? Glenn
1973 Won't Run
Re: 1973 Won't Run
That sort of voltage is plausible and probably not the source of the problem. Assuming there's fresh gas, the choke is set, it's not flooded, the accelerator pump works, I'd look at the points to see if there's a reasonable gap and the metal surfaces are clean.- Top
Re: 1973 Won't Run
- Top
Re: 1973 Won't Run
If your fuel pump filled the carb the accelerator should squirt fuel every time until the fuel is expelled and the carb needs a refill. I know airplanes sit sometimes for long periods of time and fly from the airport with fuel in the tanks that have been there for some time.- Top
