RSW bolts? - NCRS Discussion Boards
RSW bolts?
  • Mike E.
    • February 28, 1975
    • 5134
    RSW bolts?
    I'm very familiar with RBW bolts. However, on a 62, I found several of these RSW bolts. Has anyone ever seen that head on a 53-62? In what application/location? P5070148.jpg
  • William C.
    • May 31, 1975
    • 6037
    Re: RSW bolts?
    what is it holding together Mike?
    Bill Clupper #618
    • Mike E.
      • February 28, 1975
      • 5134
      Re: RSW bolts?
      Bill,
      I was waiting to mention that until I determined whether or not anyone has seen them. They would have been placed on an assembly by a supplier, not on the assembly line at either at the Flint engine plant or St. Louis.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17549
        Re: RSW bolts?
        Mike,
        RSW is not listed in the '63 Fastener Institute as a register bolt head logo. Nor is RBW. Believe RBW was or became Rockford, but don't know for sure.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Gary B.
          • February 1, 1997
          • 6979
          Re: RSW bolts?
          Originally posted by Gary Chesnut (5895)
          Mike,
          Gary
          Gary,
          What's the significance of it being listed by the Fastener Inst or not? RBW is a commonly found head mark, on C2s at least, so it's clearly legit. Can't say I've ever seen an RSW before.
          Gary
          • Gary C.
            Administrator
            • October 1, 1982
            • 17549
            Re: RSW bolts?
            As I understand it the IFI was formed to publish the head markings among other things. Is it a complete listing of all the companies producing fasteners in 1963, probably not.
            This spring 1964 publication I have is GM, SAE and manufacturer markings. This publication is the most comprehensive list of period head markings I've found other than the GM Fastener 3 book set (1200 plus pages) of which I've never been able to acquire a copy of.
            Gary
            Industrial Fastener Institute website http://www.indfast.org/default.asp
            NCRS Texas Chapter
            • Mike E.
              • February 28, 1975
              • 5134
              Re: RSW bolts?
              RBW is also very common on later C1s.
              • Michael G.
                • November 12, 2008
                • 2155
                Re: RSW bolts?
                RBW was the head marking for "Russel Birdsall and Ward", a fastener manufacturing firm.
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Re: RSW bolts?
                  I remember the RBW factory in Port Chester , NY.
                  A very large operation many years ago when I saw it.
                  I have run across a number of RBW fasteners in my 62 but I'm not sure where they were.
                  • Robert G.
                    • May 31, 1990
                    • 429
                    Re: RSW bolts?
                    Do you have a listing for Ring Screw Works in Michigan? They've been around since the 1920s.
                    • Mike E.
                      • February 28, 1975
                      • 5134
                      Re: RSW bolts?
                      I have the same document as Gary has. It lists "The Reliable Spring and Wire Forms Company", which certainly could translate to RSW. A Google search lists them in Elyria, Ohio. However, the document shows their code as RS. I do not have a Ring Screw Works listing in that document. The RSW bolt I pictured is used as a fastener in a low-production 1962 option. I've never seen that headmarking on a 57-62 before. Has anyone else seen it anywhere?
                      • Michael G.
                        • November 12, 2008
                        • 2155
                        Re: RSW bolts?
                        Ring Screw Works was an independent fastener manufacturer who supplied many fasteners to GM. They are now part of another company. I have never seen them use RSW, they normally use a circle (ie: "Ring") as a mark.
                        • Gary C.
                          Administrator
                          • October 1, 1982
                          • 17549
                          Re: RSW bolts?
                          Ring Screw Works is at the bottom of page 37 in the 1964 IFI fastener head bolt marks
                          NCRS Texas Chapter
                          • Bob J.
                            • December 1, 1977
                            • 713
                            Re: RSW bolts?
                            HD brake covers
                            • Mike E.
                              • February 28, 1975
                              • 5134
                              Re: RSW bolts?
                              Bob,
                              Sent you a private message.
                              Mike
                              Originally posted by Bob Jorjorian (1619)
                              HD brake covers
