C3 Spongy brake pedal. - NCRS Discussion Boards
  • Daniel S.
    • February 1, 2000
    • 164
    Re: C3 Spongy brake pedal.
    You've got me beat. I've never done any better with the Motive than any other method, and the Motive seems to be excellent at spilling brake fluid everywhere OR pushing the fluid out of the system and leaving one of the bowls dry. Several uses later I figure that there must be an art to using one, but I'm not an artist.
    Before I purchased the Motive product I had learned about others have issues getting the adapter to seal on the master cylinder. The new adapters they sell that fit vintage Corvettes are made of metal where the older ones were originally plastic. I picked up a C clamp at the hardware store that opens wide enough and it worked great. Plenty of space for the C clamp on the in board side of the master cylinder.
    • Paul J.
      • September 9, 2008
      • 2091
      Frank, you said that the car pulled right when braking. This means the left front hose has failed. While you can get by OK with replacing one caliper, you should always replace both or all hoses. The fact that the pedal moves slowly to the floor with the motor running is a different issue. As other have mentioned, it means that the MC is bad. The fluid is leaking internally past the seals. This is pretty common.
      Paul
      • Mike T.
        • January 1, 1992
        • 568
        #18
        Same approach here with the Motive Bleeder, I used a large C-clamp to hold the adapter in place.
        Mike T. - Prescott AZ.
        • Frank K.
          • January 1, 2000
          • 319
          #19
          Did find bad hose . Tried to blow thru it with mouth (restricted) Place compressed air on it (okay) Whats the proper way to check? Also master cylinder new last year but had hard pedal after replaceing with new unit. Any other suggestions? And thank all members for there input Frank
