I recently pulled the motor out of my father's 1966 convertible. He was in the process of replacing it with the 3858174 block that was original to the car. The block being replaced has part code 3970010, date code B169 and V0299800 Stamp.
From what I have read, the 3970010 blocks were only produced from 1968 thru 1979. Does anyone know if that is correct ? If it is correct, how do you know if the date stamp is for 1969 or 1979 ?
I read on another posting that the V0299800 stamp "is a 1979 GM service TargerMaster 350 GM service parts engine. There is no advertised HP that I have ever found but its safe to say they are not intended to be high performance engines, just generic 350 replacements." Can anyone verify that?
The block is a 4 bolt and the dipstick is on the driver's side.
If so, any idea of value?
Thank you for your knowledge.
Jeff
Jeff
