Can anyone describe or post a photo of the correct dipstick tube orientation on a fuel injected car? I understand that it was rotated 45 degrees "clockwise" to avoid interference with the air cleaner assembly. I take this to mean towards the rear of the car.
C1 Fuel Injection dipstick tube orientation
Re: C1 Fuel Injection dipstick tube orientation
Keith, Not sure about 58/60, but 62 was closer to 90 deg as per 62 Assy Manual Section 582, sheet 5. My 62 is an early s/n Nov build & is exactly as shown in Assy Manual. They say "Install dipstick tube with plane of bend parallel to center line of Crankshaft". It is sometimes a little hard to get the dipstick out as you are pulling toward the firewall hood latch. Good Luck
Barry Holmes- Top
Thanks Barry. So yours is facing forward then? Good idea to consult the AIM. I'll check the '60 to see if it specifies the orientation.Keith MacRae
NCRS #36692
New Mexico Chapter
1960 290HP FI
2013 427 Convertible
Shade tree mechanic and
B-52 pilot extraordinaire
- Top
Sure enough. The '60 AIM says the same thing. The tube is aligned parallel to the crank centerline facing the dash. Thanks.Keith MacRae
NCRS #36692
New Mexico Chapter
1960 290HP FI
- Top
Keith MacRae
NCRS #36692
New Mexico Chapter
1960 290HP FI
- Top
