Bench Check Fan Blower - NCRS Discussion Boards
  • Dale C.
    • November 1, 1999
    • 844
    If I pig tail off the positive terminal of a twelve volt battery to the connector and just ground out the motor at one of the bolt holes, with a good contact, shouldn't the fan motor work at full speed? It doesn't turn at all. I show about 11.75 volts. Do I have to power up, as on the car though the resistor and the relay, to get it to work. Maybe it is just a burnt up motor. It does turn freely.
    Dale
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Bench Check Fan Blower
    i'd look for a replacement motor. way u hooked it up ought to spin. think brian tills at corv spec of md(now so cal) has them .mike
      • 6940
      Dale, Just be sure of your ground connection, If the area has paint it may not ground properly. But as Mike says should work.
      • Dale C.
        • November 1, 1999
        • 844
        I have a good working repo (GM Canada) in the car but was trying to get this late 67 dated one in. I'll try again and use a different gnd.
        Dale
        • Dale C.
          • November 1, 1999
          • 844
          Got it. It was a bad gnd.
