Any advice on how or who to send tumblers to for work? My glove box door lock will not pass a PV, if the key is turned 45 degrees it still pulls out of the lock. Also my spare tire lock I am told is a universal set, and will accept my ignition key. Botha re PV failures. I have not picked locks since HS and don't have the first idea how to repair either of these.
Tumbler - work
- Top
Re: Tumbler - work
If you have a '65 spare tire lock, then it's correct that the ignition key should insert into it. It just shouldn't open it. Universal keyway spare tire locks were non-production replacements for '67 thru '79 spare tire locks. For '65 and '66 both the primary and secondary keys used the same, groove 15 keyway, so any '65 or '66 key will insert into any '65 or '66 lock, spare tire or otherwise.
Gary- Top
- Top
Re: Tumbler - work
Ronald,
A proper '65 ignition key will fit all the way into a proper '65 spare tire lock.
Now maybe your ignition lock (and key) has been replaced with a later unit that takes a '67 or newer "letter" key, which has a different keyway. In that case, you have a bigger problem in order to get back to original.
Gary- Top
Re: Tumbler - work
By any chance does the ignition key that you're trying to insert into the spare tire lock have a letter stamped into the upper end of the blade? Like an A, C, E or J?
Gary- Top
Re: Tumbler - work
Send your locks to Pete. I saw him briefly at the North Central Regional. He did the locks on my car, and I passed PV in 2011. Great guy. Good luck on your PV!Chris Enstrom
2011 Z06, red/red- Top
Re: Tumbler - work
Ronald,
Here's his contact page on this board:
https://www.forums.ncrs.org/member.p...ahl-%286598%29
Joe- Top
