1969 lap belt guides - NCRS Discussion Boards
  • Robert N.
    • November 9, 2011
    • 67
    I have seen several versions of C3 lap belt guides that sit under the outside corner of the seats that the belt goes under. There is a 4 bolt version as well as 3 bolt, and I have seen guides both with and without the protective rubber strip on the top edge. The one on the right came from a July 69 coupe. When were the 4 bolt versions used and which is correct for a Feb 69 build? When did the protective strips start?
    Thanks, Robert
    • 15573
    Re: 1969 lap belt guides
    Just a dumb question before I have to do it. Have you looked in the Assembly Manual?
    • Robert N.
      • November 9, 2011
      • 67
      AIM is no help, the "cartoon" gives no indication and the guides have no PN stamped on them to reference. Also trying to determine if there was a mid-year change between 3/4 bolt and with/without rubber strip.
      Robert
        • 15573
        Robert
        I would like to satisfy myself. Can you help me witth a UPC number and Sheet number to make my search a little less lengthly?
          Thanks, Robert
          [ATTACH=CONFIG]52981[/ATTACH][ATTACH=CONFIG]52982[/ATTACH]
          Robert------
          There were at least 3, and possibly 4, different designs used for these reinforcements during the 1969 model year. I do not know when each design change was introduced. However, the final design went into PRODUCTION very late in the model year, probably not before October, 1969.
          • Roger G.
            • October 11, 2012
            • 268
            Thanks, Robert
            my march 11 has the 3 bolts with rubber on top.... Just had them out 2 days ago
            • Robert N.
              • November 9, 2011
              • 67
              Terry, the AIM location is ASM 1, F26, p134. The AIM shows PN 3976463/4.
              I cleaned up the 4 hole guides, and there is the [triangle steer] logo and part numbers: 3966693/4.
              The 3 hole version has the [triangle steer] logo but no part numbers. Also it appears to be flash chromed, while the 4 hole looks galvanized or cad plated (no expert on finishes)
              Roger, can you take a look to see what PN you have? it is on the upper side between the two rear bolts.
              Thanks, Robert
              • Roger G.
                • October 11, 2012
                • 268
                Thanks, Robert
                Robert,
                I have the three hole version. They appear to be galvanized. I could not see a part number. They are now back in the car, so I couldn't look on the bottom side.
