Is this caused by a steering box problem or a tie rod problem
Steering Bump 1959
Re: Steering Bump 1959
If you are referring to a point in turning the steering wheel at which the steering effort become momentarily greater, this is due to defects inside the steering box. Typically, the sector roller has either dents or small chunks of metal missing. There are rebuild kits with new sector rollers and new worm gears.
Jim- Top
- Top
