Hi, was on a short drive this morning, just about home in the 54, pulled up to a stop sign and the car just stopped, no spit or sputter but just stopped. Tried to start but nothing, got under the hood, thought maybe neg. came loose, wiggled and tapped wires to starter and n. safety switch, battery and that was it, turned key and it started right up. Any idea's? Thank's, Brad.
54 stalled
Re: 54 stalled
Check your ground on the drivers side of the engine.
Make sure you have a good ground
Check the points, wires tight
Check the connections at the coil and at the connection coming thru the ing shielding....
Couple things off the top of my head....1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
Re: 54 stalled
Thank's Chris for the info, I do recall in the past the shielding and I believe distributor wire were touching and grounding out but do not recall if it cranked and would not start or no action at all, will check all connection's for proper contact. Would the coil going out do this? Seem's on my 58 when coil was going out it would just run poorly on occasion till on a drive one day boom, big backfire and coil was gone. Than you, Brad.- Top
