65 Vette - NCRS Discussion Boards
65 Vette
  • Greg D.
    • June 30, 2004
    • 62
    Re: 65 Vette
    Of course they are convertibles. Joe has it right.
    • Joe C.
      • August 31, 1999
      • 4598
      Re: 65 Vette
      Originally posted by Robert Keese (7713)
      Not true! As I stated above the fan clutch caused my bone stock 62 to overheat at highway speeds. I change it, it fixed it while on the road. Not many variables there. That was 20 years ago and it is still fixed.
      As little a 4 degrees too retarted initial timing can cause over heating at an idle. It is possible you have 2 problems. Advance the timing 4 degrees at an idle and see if your overheating disappears at an idle. It's quick, easy and it don't cost a dime.
      You should carefully re-read sentence five in the post that you criticized, and think it through.
      Keep in mind that I'm addressing his "overheating" issue at highway speeds.
