1966 rocker molding support bracket - NCRS Discussion Boards
  • Joseph R.
    • June 19, 2011
    • 63
    could someone advise where to weld rocker molding support bracket on 1966 coupe. if i could get a measurement from the front of rocker channel for each support that would be helpful. they were all rusted out and we have replaced that potion of birdcage and this is the last step. welder is coming tonight so any help today would be appreciated. i could not find measurement in assembly manual and one of the pages has an error on the number of supports on the drawing i think
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: 1966 rocker molding support bracket
    If you use the chrome sill molding as a pattern you should be able to determine the welded bracket locations by measuring the distance between the mounting holes on the bottom of the sill molding and transferring those dimensions to the birdcage. Unfortunately, I can't provide the dimensions as my car has side pipes and no brackets.
    • Joseph R.
      • June 19, 2011
      • 63
      unfortunately i dont have moldings. if anyone can help w dimensions it would be helpful thanks all
