1970 front shock absorber washer/retainer? - NCRS Discussion Boards
  • Mike F.
    • April 25, 2011
    • 668
    Which is the correct washer/retainer for the front shock absorber? I have three different sizess in the parts bin. The correct part number is 3790342, but I don't know the dimensions.
    TIA,
    Mike
  • William C.
    • May 31, 1975
    • 6037
    Re: 1970 front shock absorber washer/retainer?
    Which suspension do you have?
    Bill Clupper #618
      • 15573
      Configuration looks like the one on the left, but I am hoping the distortion in shape (in the picture it looks oval to me) is due to the camera lens. Finish should be dark phosphate and oil. I am not sure if the center hole is the correct diameter again because of photo limitations.
        TIA,
        Mike
        Mike------
        The one on the left.
        • Dick W.
          • 10483
          Here is a photo of what I sold for years. At one point they were available from the General, since discontinued now
          Dick Whittington
            [ATTACH=CONFIG]53118[/ATTACH]
            Dick------
            The GM #3790342 was first used for the 1962 Chevy II application. Their Corvette use began for the 1965 model year and continued right through 1982. They were finally discontinued about 5 years ago. They were used with a specific bushing, GM #3790341, which are also discontinued.
              • 3415
              Hi Mike,
              I think your picture also illustrates the difference in 'arc' of the retainer for the front shock absorber bushing retainer (greater, and on the left), than the 'arc' in the retainers for the a-arm bushings (lesser, and in the center).
              The shock absorber retainer is on the right. 71 #6589
              • Dick W.
                • 10483
                Hi Mike,
                I have seen quite a few control arm retainer washers used in place of the shock washers.
                Dick Whittington
