Franken Carb.... - NCRS Discussion Boards
Franken Carb....
  • Paul D.
    • January 1, 1988
    • 101
    Franken Carb....
    70 Corvette LS-5 7040205 carb....came in running rough....pulled fouled plugs wet from bad gas, stuck float.....What are the correct jets and rods for this carb?.......Currently it has 75 jet in primary, couldn't get info on primary rods......Secondary rods are "CV"..I have a set of 77 jets and "CH" secondary rods as spares if needed......Car is basically stock except for Lunati Voodoo 268 cam...Is there a alcohol resistant accelerator pump material?..Thanx for any info....P..
  • Jeffrey S.
    • May 31, 1988
    • 1879
    Re: Franken Carb....
    According to a spec list provided in the tuning paper by Lars Grimsrud, the Main jet is #78, main rod is #49, secondary rod is AX. These are for stock 7040205 Quadrajet.
    Jeff
