1967 valve cover bolts - NCRS Discussion Boards
  • Robert D.
    • April 1, 2003
    • 305
    what are the correct head marks for 67 valve cover bolts? the manual says rbc but no one sells them the ones i got when i ordered them were rbw and sbc bolts were these used? ive also seen TR sets are the ones i have acceptable if not where can i get a set with rbc headmarks?
    thanx
    bob
    • 43193
    Re: 1967 valve cover bolts
    thanx
    bob
    Bob-----
    You don't mention whether you're talking about small block steel valve covers small block aluminum covers, or big blocks. In any event, there were almost certainly multiple suppliers for the valve cover bolts. I would think that any period-correct headmarking would and should receive full judging credit.
    However, if you really must have "RBC" headmarking bolts, Richard Fortier, who advertises in the Driveline, can most likely supply them.
    • Rich P.
      • January 12, 2009
      • 1361
      67 steel valve cover bolts for both big and small block would be grade 2 TR small font, SBC, RBW and occasionally RSC and NAT. The ignition wire ground bolts on BB cars with a radio are grade 5 SBC, SB, TR, NAT RSC cad plated. RBC is not a correct bolt that's a miss print.
      • Nick C.
        • August 31, 1998
        • 542
        thanx
        bob
        "the manual says rbc " NOT TRUE What manual are you looking at?
        • Mark D.
          • June 30, 1988
          • 2142
          When I judge the George Jetson cars, I like to see various headmarkings on the same car. That is to say, the valve covers, on a single Corvette, would have two or three different headmarkings. I would not deduct for the headmarkings that are all the same because circumstances could cause that.
          Kramden
          • Timothy B.
            • April 30, 1983
            • 5177
            My 67 is a 300hp with steel valve covers and the hold down bolts have a (L) and are grade two.
            • Rich P.
              • January 12, 2009
              • 1361
              Tim, Yes L!!! I had Big Block on my mind when I posted this and although they were also used on the Big Blocks occasionally they seem to be the red headed stepchild of BB V/C bolts. Very common on SB cars.
