Wire Crimping Tool Recommendation
Re: Wire Crimping Tool Recommendation
The discussions about hand crimping being acceptable under any circumstances without solder follow-up. For most of the larger gauge sizes we used crimp and solder approach as I described. NOTHING was hand crimped.Bill Clupper #618- Top
As did ours as crimp technology improved thru the years, (37 years at Packard Electric Division of GM/Delphi) Engineering, Quality Control, Mostly in the "heavy Manufacturing" areas, Terminal Make, Lead Preperation (terminal to wire application) later in life, Customer Satisfaction, Warranty and the like, then Component design, plastic & metal.Bill Clupper #618- Top
I do solder wires occasionally (with heat shrink of course). I a correct crimp and a correct solder are equal in reliability.
Soldering like crimp requires a good tool. If your soldering gun or iron is old and not generating enough heat, you can end up with a cold solder joint (the solder didn't flow correctly). And a free hanging solder joint can work harden in a vibration application which is why you use heat shrink (which everyone here does). The heat shrink acts as a strain relief. It also keeps oxygen off the soldered joint.
The differences in heat shrink could drive you crazy too. Our Raychem heat shrink catalog was over an inch thick.
I do have a little bit of very high quality heat shrink in the shop. The inside of this heat shrink is coated with a heat activated glue, it will even stay sealed under water.Dick Whittington- Top
for what it is worth, I just did a wire splice/crimp under the dash and was also very upset about putting the normal crimp tool under the dash. Especially by the fact that mine had the crimp part in the middle of the tool. I finally thought to take a small pair of wire dykes (cutters) and grind off the blade on the tip so that it was flat and spaced the same as the crimp tool. this worked great and should work for others as well, even if not under the dash......Bruce- Top
If you use that method, make SURE you solder the crimp.Bill Clupper #618- Top
Kevin,Can you tell who makes your tool? Does it have replaceable jaws for different tasks? Looks like one in SnapOn catalog-bet it costs more than you think, at least new/now.- Top
Bill, nice to see another wiring guy here. I have worked for one of Packard's competitors for 32 years. The first time I encounter crimp and sweat was when we got our first GM contract in the mid 80s. I was the project engineer and had previously only worked on Ford and Chrysler products. I am still working in the wiring industry. Modern terminal designs don't require crimp and sweat, when crimped to the proper specification they will form a long lasting gas tight seal on even the largest terminals. A crimp which forms a gas tight seal is a must for a good long lasting electrical performance.
I would solder any had applied terminal, even ratchet crimped terminations. The reason for this is every terminal/wire combination has an optimum crimped height and width. If you don't know the crimp specification, there is no way a ratchet crimper can duplicate the optimum crimp. A very small amount of solder added on the conductor crimp seam will wick into the crimp and seal the connection. Don't over do it, to much will wick down the wire and make it stiff. You will then risk breakage behind the insulation crimp.
Many years ago, I did some milli-volt drop testing on a family of terminals we were having trouble with. By adding a small amount of solder, the milli-volt reading dropped to acceptable levels and were much more consistent. In that particular case, the fault was with the terminal design. However, the same principle applies to connections not crimped to the optimal condition.
As did ours as crimp technology improved thru the years, (37 years at Packard Electric Division of GM/Delphi) Engineering, Quality Control, Mostly in the "heavy Manufacturing" areas, Terminal Make, Lead Preperation (terminal to wire application) later in life, Customer Satisfaction, Warranty and the like, then Component design, plastic & metal.- Top
