Any suggestions on where to buy a complete rear leaf spring assembly for judging? I currently have a mono-spring installed from the prior owner. Thanks...Don
69 complete rear leaf spring, big block
Re: 69 complete rear leaf spring, big block
Don, flea bay, Driveline, craigslist, it will take some time to find a good spring. Just keep in mind its a used piece, there is a risk. About the only reproduction spring that is correct is the 7 leaf from Americas finest Corvettes. Eaton spring from Detroit Mich. has a pretty close 9 leaf reproduction spring but not as the original 9 leafs.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
How about the Dr Rebuild set-up?
- Top
Don, No one makes a 100% correct spring If you want something that's close Eaton Spring is the only choice. there maybe a correct one down the road. My understanding is the Americas finest Corvettes maybe in the process, At least that's what he told me a few years ago at Corvette of Carlisle.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
America's Finest Corvette is re-making the 7 leaf spring. Also, suggest you run a wanted ad for an original in the NCRS Classified Ads forum.
- Top
Don, I am not 100% sure, But if your car has a rear stabilizer bar it must be a 7 leaf. if so Americas finest corvette in California sells the correct spring. Lets see if some else answers on the big block spring. If you have a 68/69 JM manual it should spell it out in the chassis section.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
The 7 leaf rear spring was supplied as part of the F-41 HD suspension option. It was AVAILABLE with L-71 but it was not part of the L-71 engine RPO. Only slightly over half of the Corvettes equipped with L-71 were also equipped with F-41.
So, how can you tell if yours was one of them:
1) tank sticker
2) front springs would have 0.7" wire diameter
3) assuming that the rear shock mount support shafts are original, check for forging number:
3820929-30= standard suspension
3829265= F-41 suspensionIn Appreciation of John Hinckley- Top
Edward-----
Rear stabilizer bar was part of big block engine options; it was not part of ANY 1965-73 F-41 option.
The 7 leaf rear spring was part of 63-74 F-40/F-41 HD suspension option. For 1969 it was available only with L-71 and a required option for L-88/ZL-1.In Appreciation of John Hinckley- Top
Don, I am not 100% sure, But if your car has a rear stabilizer bar it must be a 7 leaf. if so Americas finest corvette in California sells the correct spring. Lets see if some else answers on the big block spring. If you have a 68/69 JM manual it should spell it out in the chassis section.- Top
Thank you Joe. I knew if I waited a while that I'd get the correct info. So, I have the base 427/390 HP with TH400 auto trans in a couple and know I know the 9-leaf is correct to apply. My car is originally from Canada so I have GM transfer data for the car and there is no info on HD suspension. It has this info:
GM Canada Import Documentation
Production Plant = St. Louis, MO
Shipping Date = Nov 17, 1969
Engine = 427 CID 390 HP 4bbl Turbo Jet V8
Dealer: Stedelbauer Chev Olds Ltd. Edmonton, AB Canada
Trim: Std Black Vinyl
Paint: 980-Riverside Gold
Options: A01; C50, GS2, G81, J50, K05, L36, M40, N40, PU9, U69; W84; ZQ4
I'm not sure what option code GS2 is unless it's my typo from hand transferring that data into a word many years ago.- Top
Any comments on the correctness of this ebay unit? I current have a mono spring; what other components would be needed to mount this?
- Top
