My symptom is the left tie-rod end contacting the tire ,while the right has about 11/2 inch clearance in the same area. This lack of clearance is consistant regardless of steering angle. I've recently changed from the 775x15 bias tires to a set of 205x75x15
Tiger Paws. But, these are supposed to fit with no problem. The car runs straight & I'm not seeing how alignment could be an issue...? I do see about an inch of threads exposed on each of left tie-rod ends and, only a half-inch on each of the right side ends. I'm not sure what that means . Really, the only thing I can see is possibly a bent
steering arm on the left side allowing the tie-rod end to be too close to the tire when installed ? Can a few of our Chassis & Steering experts give me some real ideas?
I really appreciate the assistance!
RALPH
RALPH
