I am trying to locate a Good resource for exhaust manifold restoration who is reliable and restoration worthy of an NCRS grading. Can anybody provide pointers to a few places? I tried a place out west here in Norcal who stated they offered the service but after four attempts to get more details and no replies, I have given up on their non-responsiveness... Thanks in advance.
Re: Good resource for exhaust manifold restoration who is reliable and restoration wo
Is your goal exhaust manifold restoration without a deduction in NCRS judging?
If it is, depending on the class your car is in (what year it is), your goal may be unrealistic.Terry- Top
I am trying to locate a Good resource for exhaust manifold restoration who is reliable and restoration worthy of an NCRS grading. Can anybody provide pointers to a few places? I tried a place out west here in Norcal who stated they offered the service but after four attempts to get more details and no replies, I have given up on their non-responsiveness... Thanks in advance.Perhaps I should have asked you what you mean by the above bolded statement in your opening post.
I assUmed you were looking for a restoration service the results of which would result in no judging deduction. Am I wrong?Terry- Top
Terry, You are correct, no points deduction. I have a set of very un-pitted manifolds with air tubes and check valves all needing a cosmetic clean-up, air tubes removed, and busted stud replaced (or all studs replaced).- Top
Then beware of coatings added to the manifold. Some exhaust manifold restorers like to do that as a means of preventing corrosion. To my eye that creates an artificial finish that is not like TFP. Of course what matters to you is not what I think, but what the person who judges your car thinks.I am trying to locate a Good resource for exhaust manifold restoration who is reliable and restoration worthy of an NCRS grading. Can anybody provide pointers to a few places? I tried a place out west here in Norcal who stated they offered the service but after four attempts to get more details and no replies, I have given up on their non-responsiveness... Thanks in advance.Terry- Top
Jerry McNeish does a VERY nice job on intake and exhaust manifolds.
He has done several for me -1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
Exhaust manifolds are raw cast iron and rust quickly and easily. If you "restore" them and add a coating to protect them (paint, calyx, etc.) you will receive a deduction during judging.
I'm guessing your goal of zero points deduction would be very difficult to maintain for any length of time. In theory I guess you could soak the manifolds in Evaporust for a day or two before judging and then bolt them on before you go.- Top
Hi Greg,
A good question, especially since you describe that you have very nice manifolds.
I believe it's VERY difficult to retain ALL the points for the entire exhaust system on a restored car, so don't be too frustrated by some deductions.
Make the best choices you can that fit into your approach to 'restoration'.
Alan71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
You might want to have the tubes removed and the stud removed, then spray them with Pre-Lube 6 or a similar protectant. It's a heavy oil, which will burn when you first start the car, but they look great for a show car and the oil can be easily reapplied. No deductions have resulted for me so far in using this method. Any other paint, coating, etc will result in a finish deduction.Vice-Chairman (West), Michigan Chapter NCRS
When I judge, if the manifolds don't have some discoloration (at least) or minor rust, it's a small deduction. Certainly, you should 'restore' them as you wish because it is, after all, your car. However you do them, as long as your happy, they will be right.
Unless you dig rust, your goal of zero deduction might be problematic. As a wise knower of all things Corvette (from deep in the Florida swamp) once told me..."if it ain't rusty, it ain't real."
May the rust be with you,
KramdenKramden- Top
[QUOTE=Mark Donnally (13264);709868
Kramden[/QUOTE]
Kramden,
I think I know that fellow and you're right about him being wise beyond his age.
He spoke at our club gathering one year and the crowd was speechless.
Have you heard his thoughts on car shows ain't a beauty contest or the one on ugly cars are usually the most intersting?
May rust follow you through life closer than your shadow, Bob J- Top
One day, oh wise one, I shall ****** the pebble from your hand.
Until then...rust is a must!
****** must be a bad word....OK, grab the pebble from your hand:-))Kramden- Top
Gents,Thanks for the feedback. Are there any other resources you can recommend aside from Jerry M as I am hoping to contact several places before selecting one. Additionally in looking at Jerry M's website (Thank you ChrisS for the link ) and I see JerryM is coating the manifolds and several of you are suggesting a preservative which does not rust over time is a bad judging choice. I know my motor will be run - in on a dyno so it will heat the manifolds and hence rust should form in time. Other suggestions are very much appreciated I need busted flange studs removed and air-tubes removed without damaging the manifold (which is in fabulous shape) or the air-tubes and I know that I am not the qualified person to do this.GregGreg- Top
