Re: Something Fried?
John,
That lug is definitely grounded. It doesn't belong there. You had a direct short from the ACC Brown wire to Ground. This short passed through the ignition switch to the 12G Red wire which feeds the switch. This 12G Red wire comes from the bulkhead connector which eventually comes from the buss bar on the horn relay, through a rubber plug-in connector, and is tied to a 10G Red which comes from the BAT terminal on the starter solenoid. There is no fusible link tied to the battery located at the solenoid post. I believe the "fusible link" is the 16G Black wire with a small rubber plug connector at the horn relay. It connects the 12G Red from the IGN switch to the 10G Red from the Battery post at the solenoid. I never had one of those go bad but that's the suspect in my opinion.
Here are some photos of the items in question from a old '67 Forward harness I had on the shelf. I added some arrows and text to describe.
So.....You cannot test the fusible links or circuits without a meter, or without a test light if the circuit is powered. For now, do UN-powered tests with a meter. A link is a finer wire than it's load wire, inside the rubber, and will melt if blown, and it may or may not show external evidence of failure. So your visible checks of the links near the alternator/regulator are not accurate and could still be a problem, along with the one near the horn relay. You must test them with a instrument mentioned above.
The other possibility is you've damaged the ignition switch. Again, a meter or test light at the various source and destination points in these circuits is the best way to diagnose the fault and find root cause of the failure. You should have 12 volts on the 12G Red at the IGN switch at all times. If not, the fusible link at the horn relay buss bar is likely blown.
Curiously, what does that Radio Capacitor wire end look like? Is there and male terminal on it's end? That's where the Brown wire connector should connect.
Rich
John,
Rich
