I was putting the clock back into my '67 and noticed a loose wire near the ignition switch. Assuming that my groping around under the dash pulled the wire loose, I reattached it to where it appeared to go - right above the ignition switch.
I turned the engine over to make sure everything was okay and it started-up, ran for 2-3 seconds and died. Now everything is dead. I took the wire off and rechecked but only the horn is working - WTF? Clearly something got fried... main breaker... I'm not even sure where to look. Help. John
............While I'm out maybe someone else can add some ideas too.
