I tried to replace the "donut" gasket on the right side (1970 454) between the pipe and the heat riser. I purchased a gasket from the local NAPA store and found that I could not start the nuts to the studs as there was insufficient thread available.
The height (or width) of the gasket is about 9/16". I called a number of the corvette specialty parts houses and they all said that the gaskets they sell are the same height. Is this gasket a specialty item? The studs on the manifold appear to be the correct length, does anyone know the correct length of the studs?
Gene
Gene
Anyway 3/8" seems thick to me, but maybe, but I'll try to crawl underneath tomorrow night and take a peek! regards, Rich
