Correct Top Ignition Shield Bolt - 1964 - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2640
    Is the top ignition shield bolt on my '64 supposed to have an integral lock washer or an integral external tooth star washer? The current TGJM says it should be a recessed hex-head bolt with an integral external tooth lock washer.
    I currently have a recessed hex-head bolt with an integral lock washer.
    James West
  • Peter L.
    • May 31, 1983
    • 1930
    Re: Correct Top Ignition Shield Bolt - 1964
    James - The 63-64 Corvette AIMs call out SCREW ASM 423554 while the 65-67 Corvette AIMs call out SCREW ASM 423553. Interesting. I don't know what the differences in the SCREW ASM is but I can tell you that the top ignition shield bolts/screw asms on our 66 & 67 Base Engine Corvettes with U69 have the recessed hex-head with integral "wide-ear" tooth lock washer & the "RBW" headmark. Pete
    • Timothy B.
      • April 30, 1983
      • 5177
      Pete,
      Does the hold down bolt look like this one that's on the ground strap and top ignition shield on my 67 300hp engine.
      • John S.
        • May 4, 2008
        • 424
        Same for 65 TI ignition car?
        John Seeley
        67 Black/Teal
        300 hp 3 speed coupe
        65 Maroon/Black
        35k mile Fuelie coupe
          • 6940
          Originally posted by Timothy Barbieri (6542)
          Pete, Does the hold down bolt look like this one that's on the ground strap and top ignition shield on my 67 300hp engine.
          Tim, My 63 top shield bolt is like configured like yours only It has a (L) head mark. The ground strap bolt on accelerator lever is a 3/8's head self tapping style and no marking on the head of my bolt.
          • Ara G.
            • January 31, 2008
            • 1108
            From memory, the ones for 67's are E, EL, L, as well as others. Configuration looks like the above pics. ARA
            • Peter L.
              • May 31, 1983
              • 1930
              Tim - Yes. I guess the same person put them together on the line. It's interesting because the 67 AIM call out is for a separate SCREW #106962 & a separate Lock Washer 138489. Pete
              • Harry S.
                • July 31, 2002
                • 5258
                My April 63 has an E my July 63 has an O. Are any original, who knows?
