%5Burl=https://postimg.org/image/a7yn0xjxr/%5D%5Bimg%5Dhttps://s19.postimg.org/cpae873ub/IMG_2164.jpg%5B/img%5D%5B/url%5D
Hmmm
Re: Hmmm
Jack,
I have, for years done just as you describe but now, when I paste it, the format changes from what I copied so it shows as in my first post...and no pic.
Photobucket was were this began so I changed to Postimage and it worked well, for awhile.
What did you add to my link to make it work.
Mark- Top
Re: Hmmm
Jack,
Mark
For example... this was your code from Post #1:
Instead of the leading/opening BRACKET ' [ ' ... I see %5B
Instead of the trailing/closing BRACKET ' ] ' ... I see %5D
(there are several sets of brackets within your code)
No idea why that is converting over for you... are you using a different/new/updated browser?
QUESTION: Did you somehow accidentally switch/reset your editor window for replies?
Check the ICONS in the top left... above the BOLD and ITALIC buttons.
Play around... check your USER PROFILE settings to see if you are using the Enhanced Interface (Message Editor Interface).
If all else fails, shoot me a phone number in a PM and I can try working with you.
That is, unless the the ADMIN have another suggestion.
Good luck,
Jack- Top
Re: Hmmm
Hummm... I was looking for this before, but the button was grayed out:
Try pasting the link a PLAIN TEXT... see if that helps.
NOTE: I had to hit the A/A (first button on the left) a few times to make the PLAN TEXT button available.Attached Files- Top
Re: Hmmm
Just Wondering: After you COPY the link from the image website, try to PASTE it into a text editor first (like Notepad)... do the BRACKETS remain, or are they converted to 'characters' already? It should look like this:
HTML Code:[url=https://postimg.org/image/a7yn0xjxr/][img]https://s19.postimg.org/cpae873ub/IMG_2164.jpg[/img][/url]
Re: Hmmm
Couple More Options:
Have you tried to HIGHLIGHT & COPY the URL from the image website... instead of using the icon on the right?
Like this:
If that is still not helping, what about trying to MANUALLY insert the image?
Depending on the browser you are using, RIGHT CLICK over the image and select either...
COPY IMAGE ADDRESS for Chrome... or
COPY IMAGE LOCATION for Firefox.
Chrome Example:
Firefox Example:
NOTE: The address/URL for your image is:
HTML Code:https://s19.postimg.org/cpae873ub/IMG_2164.jpg
Here is my try inserting the image via the above steps:
I sure hope something works for you... please keep us posted.- Top
Re: Hmmm
I opened https://s19.postimg.org/cpae873ub/IMG_2164.jpg
and then copied to the insert image button above as per Jacks instructions.
Attached Files- Top
Re: Hmmm
After a HIGHLIGHTING the URL (Pick & Drag -or- Double Click), you can COPY with a few techniques:
1) RIGHT CLICK and select COPY from the dropdown menu (see below):
2) Use keyboard commands... holding the CONTROL (Command for Mac) + the letter 'C' a the same time.
(NOTE: CONTROL + V is often used to PASTE something you've just copied.)Attached Files- Top
Re: Hmmm
and then copied to the insert image button above as per Jacks instructions.- Top
