Test copy paste from Summit page
  • Richard M.
    Super Moderator
    • September 1, 1988
    • 11084
    #1
    Looks good when I paste it in edit mode....
    BUT LOOKS LIKE THIS AFTER SUBMIT..... YUK!
    Brand:
    Speed Pro
    Manufacturer's Part Number:
    L-2268NF 30
    Part Type:
    Pistons
    Product Line:
    Speed-Pro Forged Pistons
    Summit Racing Part Number:
    SLP-L2268NF30
    UPC:
    019826077608
    Piston Rings Included:
    No
    Bore (in):
    4.280 in.
    Bore (mm):
    108.712mm
    Stroke:
    3.766 in.
    Engine Stroke Type:
    Stock
    Rod Length:
    6.135 in.
    Piston Style:
    Dome, with single valve relief
    Piston Material:
    Forged aluminum
    Compression Height (in):
    1.765 in.
    Dome Height (in):
    0.300 in.
    Piston Head Volume (cc):
    -36.30cc
    Wrist Pin Style:
    Press-fit
    Wrist Pin Retainers Included:
    No
    Wrist Pin Included:
    Yes
    Pin Diameter (in):
    0.989 in.
    Piston Ring Thickness:
    5/64 in. x 5/64 in. x 3/16 in.
    File Fit:
    No
    Gapless:
    No
    Quantity:
    Sold as a set of 8.
    Notes:
    DurOshield® coated piston skirt.
    In-Store Pickup:
    Choose In-store pick-up (OH, NV, GA, TX) on our web site.
    Calculator
    Compression Calculator
    Tool
    Stroker Combinations
    Speed-Pro forged pistons are made from extruded VMS-75 aluminum alloy that's forged under 3,000 tons of pressure to "near-net" shape. After that, they're machined to their final configuration. These pistons offer excellent strength and durability—and are capable of taking the punishment that's dished out on the street and in competition. They're available for a wide variety of applications, including OE replacements and all-out racing engines.
  • Richard M.
    Super Moderator
    • September 1, 1988
    • 11084
    Re: Test copy paste from Summit page
    try it again.....
    After hitting REMOVE FORMAT BUTTON
    Brand:Speed Pro
    Manufacturer's Part Number:L-2268NF 30
    Part Type:Pistons
    Product Line:Speed-Pro Forged Pistons
    Summit Racing Part Number:SLP-L2268NF30
    UPC:019826077608
    Piston Rings Included:No
    Bore (in):4.280 in.
    Bore (mm):108.712mm
    Stroke:3.766 in.
    Engine Stroke Type:Stock
    Rod Length:6.135 in.
    Piston Styleome, with single valve relief
    Piston Material:Forged aluminum
    Compression Height (in):1.765 in.
    Dome Height (in):0.300 in.
    Piston Head Volume (cc):-36.30cc
    Wrist Pin Style:Press-fit
    Wrist Pin Retainers Included:No
    Wrist Pin Included:Yes
    Pin Diameter (in):0.989 in.
    Piston Ring Thickness:5/64 in. x 5/64 in. x 3/16 in.
    File Fit:No
    Gapless:No
    Quantity:Sold as a set of 8.
    NotesurOshield® coated piston skirt.
    In-Store Pickup:Choose In-store pick-up (OH, NV, GA, TX) on our web site.
    CalculatorCompression Calculator
    ToolStroker Combinations
    • Richard M.
      Super Moderator
      • September 1, 1988
      • 11084
      Ok that worked better....
      But it replaced Upper Case "D" with Smiley Faces..... That's funny. Ha Ha.....
      • Owen L.
        • October 1, 1991
        • 670
        The colon capital D = a big smiley face in html coding; if there is a space between, it won't occur.
        typed as colon capital D =
        colon space capital D = : D
        • Richard M.
          Super Moderator
          • September 1, 1988
          • 11084
          Thanks Owen! Now that makes sense.
