Android pictures acting up again
  • Richard M.
    Super Moderator
    • September 1, 1988
    • 11084
    #1
    Autorotate off.....
    Rotate it 2x(now upside down) in Android sw....
    Now Rotate it 2x(now rightside up) in Android sw....
    EXIF data says Orientation 0*
    Still sideways. I give up.
    Try another known 0* oriented photo.... Worked fine
    Will try on laptop next....
    After rotation wrong, then back to normal, (explained here) then saved.... WORKED FINE!
  • Richard M.
    Super Moderator
    • September 1, 1988
    • 11084
    Re: Android pictures acting up again
    Interesting....
    Quote from above..... "When your photos exceed the max horizontal width or vertical height, vBulletin will rotate them to fit those dimensions."
    Time for more experiments.....
    Ours is 800W x 600H
    Filetype Max File-size Max Width Max Height
    bmp 293.0 KB 800 600
    doc 97.7 KB - -
    gif 293.0 KB 800 600
    jpe 293.0 KB 800 600
    jpeg 293.0 KB 800 600
    jpg 293.0 KB 800 600
    pdf 2.86 MB - -
    png 293.0 KB 800 600
    ppt 976.6 KB - -
    pptx 976.6 KB - -
    psd 293.0 KB 800 600
    txt 19.5 KB - -
    zip 5.72 MB - -
    • Richard M.
      Super Moderator
      • September 1, 1988
      • 11084
      I took these photos using my Android(Autorotate was OFF), then emailed to myself after reducing sizes to 25% of original, Then saved to my PC. File sizes after save apx 200KB.
      TEST 1 - Original on my PC 1040Wx780H. The bench vice should be at the top left corner of the photo.
      It did not rotate when uploaded. Why? It exceeds the 800W x 600H limit.
      It appears that vBulletin maintained the aspect ratio as the original width was greater than the height. Then it reduced it to 800x600, within the limits. So it did not need to rotate.
      Attributes after upload - 800x600
      TEST 2 - Original on my PC 780Wx1040H. The blue paper towel should be at the top of the photo.
      It Rotated it 90* CCW when uploaded. It exceeds the 600H limit.
      It appears that vBulletin rotated it within the WxH limits and to maintain the aspect ratio(W > H), but in order to do that, it went sideways.
      TEST 3 2nd photo above, retry. Original on my PC 780x1040
      Rotate and Save, re-rotate and Save on PC, then uploaded here. It was still 780x1040 on the PC.
      It uploaded properly with original orientation !!! WHY? no explanation yet.
      Attributes after upload - 450x600
      TEST 4 2nd photo above, retry. Original on my PC 780x1040
      Resized using Irfanview to 450x600, then upload here....
      IT WORKED!!! It did not rotate 90*, because the WxH is within the 800x600 limit.
      TEST 5 2nd photo above, retry. Original on my PC 780x1040
      Resized using Irfanview to 599Wx799H, then upload here....
      IT WORKED!!! It did not rotate 90*, but H(799) exceeds the 600H limit. ??????
      no explanation yet.
      TEST 6 2nd photo above, retry. Original on my PC 780x1040
      Resized using Irfanview to 525Wx700H, then upload here....
      IT WORKED!!! It did not rotate 90*, but H(700) exceeds the 600H limit. ??????
      TEST 7 2nd photo above, retry. Original on my PC 780x1040
      Resized using Irfanview to 800Wx600H(aspect ratio not maintained), then upload here....
      IT WORKED!!! It did not rotate 90*, it's within the 800Wx600H limit.
      TEST 8 2nd photo above, retry. Original on my PC 780x1040
      Resized using Irfanview to 600Wx800H, then upload here....
      IT WORKED!!! It did not rotate 90*, but H(800) exceeds the 600H limit. ??????
      TEST 9 2nd photo above, retry. Original on my PC 780x1040
      Resized using Irfanview to 900Wx700H, then upload here....
      IT WORKED!!! It did not rotate 90*, but W(900)H(700) exceeds the 800W/600H limit. ??????
      Attributes after upload - 771x600
      TEST 10
      Resized using Irfanview to 1000Wx800H, then upload here....
      IT WORKED!!! It did not rotate 90*, but W(1000)xH(800) exceeds the 800W/600H limit. ??????
      Attributes after upload - 750x600
      TEST 11 2nd photo above, retry. Original on my PC 780x1040
      Resized using Irfanview to 750Wx1000H, then upload here....
      IT WORKED!!! It did not rotate 90*, but H(1000) exceeds the 600H limit. ??????
      Attributes after upload - 450x700
      TEST 12 2nd photo above, retry. Original on my PC 780x1040
      Resized using Irfanview to 900Wx1200H, then upload here....
      IT WORKED!!! It did not rotate 90*, but both W(900) & H(1200) exceeds the limits. ??????
      TEST 13 2nd photo above, retry. Original on my PC 780x1040
      Original to test baseline 780x1040, then upload here.... Only H exceeds limit.
      Still rotates 90* CCW ???????????
      TEST 14 2nd photo above, retry. Original on my PC 780x1040
      Resize to 950x1267, then upload here.... W&H exceeds limit.
      IT WORKED!!! It did not rotate 90*. both W(950) & H(1267) exceeds the limits. ??????
      Need to SAVE now to check photo attributes on the server.
      See attributes after each photo after using the "Inspect" button for each photo, in RED. Also the edits after I saved.
      SUMMARY of experiments....
      1.
      If the photo is above the 800W x 600H pixel limitation, but its aspect ratio is consistent(W > H), it will reduce the pixel count to within the WxH limits, and it will upload properly.
      See TEST 1
      2. If the photo is above the 800W x 600H pixel limitation, but its aspect ratio is NOT consistent(i.e. H is > W), it will rotate the image.
      See TEST 2
      3. It appears, "inconclusively", that if the photo has one attribute below it's limit, either W or H, it will resize within both limits and NOT rotate.
      See Tests 5, 6, 8
      4. If the photo is below the 800W x 600W limit,
      See Test 4
      5. Inconclusive results after all this. It appears once the file is edited in Irfanview, it will never rotate. Geeesh!
      See Tests 10, 11, 12, 13, 14
      It's because of this..... Irfanview modifies the file, as does a PC or MAC. See....
      https://www.forums.ncrs.org/showthread.php?131509-Photo-Upload-Rotation-Issues-and-EXIF-Education
