In the course of re-carpeting my 77, I removed the interior quarter panels. They are held in place, partially, by a long, thin plate that "sandwiches" the rear of the door frame between the plate and the interior panel. Although my interior panels are in very nice condition, some of the reatiners that are pressed into the panel and accept the 4 screws that attach the plate are pulled out. Are there any suggestions on how to best hold new retainers into the plastic panel? Is a little epoxy in order? Thanks Steve
77 interior quarter panel retainers
Re: 77 interior quarter panel retainers
Depending on how "bad" the holes in your panel are, you can either press the inserts directly into the existing hole, or use the supplied epoxy that comes with the kit.
The screws are correct, same thread, length, and head.
I used this kit on my 72.
George- Top
