Can someone tell me what is the correct orientation of the stearing wheel onto the colum. what I need to know is what position the two rolled pins installed into the hub to cancel the direction signals are in. Do I face them to the left or right. Also does the horn brush contact get installed from the top or bottom side. Thanks!!
Don
The steering wheel is installed so that the 2 rolled pins are vertical, on the side towards the outside of the car (where the turn signal mechanism is). Approximately 8 and 10 o'clock.
The horn brush contact is installed from the top. Clean off the contacts on the column and the brush to that you get a good connection.
