Can anyone help me on removing both needle bearings & seal on '62 steering box. I've seen tools in ST-12 (don't have any). Just hoping someone has done this recently. Can I remove Pitman side bearings & seal with press and socket? The adjustment side (side cover bearings) are my main problem. Thanks for any help.
C-1 Needle bearings on steering box
Re: C-1 Needle bearings on steering box
Remove pitman arm useing a puller and then removing side cover bolts and pull unit out. Then you can also remove steering wheel and large hex nut at the box , then lower the steering shaft enough to use a punch through the side cover to drive out the rear sector seal , then bearing.- Top
