I an in the process of looking for a smog pump for my 70 LT-1. In checking around I have seen pumps that the sellers claim are 1968 or 1969 vintage by the date code on the body. These pumps had a relief valve in the body. When I find a pump with the correct date code could it have a relief valve?
C3 Smog pump
Re: C3 Smog pump
Paul:
I believe you'll find that indeed the 70 LT1 was equipped with 7801149 air pump, also used on 73-77 Corvettes (that required such). This is a different A.I.R. unit than than equipped on either 68 or 69. However, I understand, a few 72 models were equipped with 68 style pumps (relief valve). There have been a few threads in the in the past few years and you may want to search through the archives.Tom Russo
78 SA NCRS 5 Star Bowtie78 Pace Car L82 M2100 MY/TR/Conv- Top
Re: C3 Smog pump
Art,
Try Joe Marquez in Nipomo CA. He had some tough to find '66 BB smog parts I was looking for. He goes to all the local CA swap meets scavenging for this kind of stuff. If he doesn't have it, he may know someone who does. He's a straight shooter, easy to work with and reasonably priced. 805.929.2270 or 805.929.3910.- Top
Re: C3 Smog pump
I second Dan's comments about Joe - thanks to Dan's post here a year or so ago, I was able to locate the correct bracket for my 67 L79 A.I.R pump. I had scrounged Bloomington and carlisle for 2 years to no avail. Dan - where did you finally get the correct smog bracket? As I recall, Joe didn't have the correct bracket for your L36....Craig- Top
Re: C3 Smog pump
Craig- I found a guy who was selling odd-ball chevy parts and brackets on ebay. He didn't have the bracket listed, but I pinged him to see if by chance he had one. After sending $475 and another $15 for shipping, it was delivered to my door. That was the only correct 66/67 BB cast smog bracket I've seen or heard of for sale since.- Top
Re: C3 Smog pump
Paul I have a pump with the numbers 7801149 stamped on the base of it. One of the responses says it's the one for your car. There are other numbers on it but I don't know them off the top of my head. I bought the pump with a bunch of other stuff to replace my missing smog system but it doesn't quite fit my 78 L-48. If you are interested in it let me know and we can work out a deal.- Top
