Does anyone have an easy, accurate way of setting the position of the yoke that threads onto the shaft on the back side of the brake booster/ Either a measurement from the rear of the mounting bracket to the rear of the yoke or a dimension from the rear of the mounting bracket to the centerline of the clevis pin hole would be perfect. All I can find is "use some J-xyz tool" and I need a "home mechanic" approach. All help appreciated.
65 Power Brake Booster setup
